I tried your method by pulling the motor mount bolts and sliding the engine forward and found with a dry fit that I have to rotate the pump for the splines to line up. However I discovered another issue. The XRtech pumpshoe I installed is garbage. Dimensionally the thing is a piece of s**t. I spent hours filing it down during the install so it fit the hull properly, but I forgot to see how the pump would line up. I guess I figured for the price it would line up properly as long as I got the screw holes to line up and sit flat against the datum plane (flat surface the screws attach to).
I pulled the midshaft assembly and took off the pump seal and installed the pump in position. There is maybe a 1/8" gap at the top, and about a 1/4" gap at the bottom. Enough where I can get one dowel pin to line up, but not the other. Is it time to pull out a small angle die grinder and take some material off the top, or is it time for a new hull? The shoe is epoxied in with six10.
Does anyone know how far the pump seal groove should sit from the pump shoe? Hopefully I can remove some material to make it fit, but if the gap is too big, I am screwed.
