just beat the piss out of the coupler. or have you tried that?
just my two cents.....but I tried to remove a pump first and it was a pain in the arse...........next time (on a different ski, same model) I tried removing the intermediate first.....worked so much better....
I re read the original post........try knocking the intermediate in both directions then pry at different areas (but not where the bolt holes are)
once you can twist the intermediate housing without a lot of effort you should be able to pull or pry away
