Cannibal
Tasty Human
- Summit Lake, WA
Not sure WTF I did wrong here, but I put pump bearings in this pump and now the cone won't fit.
The recess from the end of the housing to the bearing is about .26" and the pump cone depth where the o-ring is is about .38" (going by memory). I grabbed a different pump cone because this was actually a 650 cone and found the same thing.
I figured the back bearing was not seated all the way, so I pulled pump shaft out and found that inner spacer sleeve tight between the front and rear pump bearings. I can't remember how I assembled this pump, but I heated it up in the oven and dropped one bearing in to the seat, inserted the spacer sleeve then inserted the other bearing. It's possible that the front bearing is seated, and the back bearing is just seated against the spacer sleeve, in which case, to solve the problem, I'd have to unseat the front bearing and seat the rear, then the impeller would end up spaced farther away from the veins. I'll play with this tonight. I suppose it's possible these bearings have a wider inner race which is preventing one bearing from being fully seated by the spacer sleeve.
This was a WSM bearing kit. I'll grab the bearing numbers when I get home, but I'm pretty sure I recall them as 6303.
Anyone run into such an issue, or any input?
