WICKED1000R
RICHIE RICH
- Port Orange, Fl
:banghead: ok...i guess i have been chasing this prob for about 2 weeks now...ok ski wouldnt go over about 1/4 throttle after about 10 min in the water....so i rebuilt the carb, put all new fuel lines, had all electronics checked, new battery.......ok ......and today i was outside messin with it...and i finnally see a puff of smoke come from under the motor...right where the drain plug is (89 650SX) ....so as i played more with the throttle the more i seen the smoke...and sometimes i just heard the puff but no smoke...so i put my hand down there...and yes its comming from the drain plug.... everytime it would puff ski would fall on its face...then when it stopped ski would rev...just like it should.....what do you think would cause this?? bad spring on the release?? or something worse?? or should i just block it off alltogether?? if i should block it off does anyone sell the block off plate??
Thanks again,
RR
Thanks again,
RR
