Prop Recommendation (JS550 750 swap with 750 Pump)
smokeysevin
one man with a couch
Houston
I am (hopefully) getting near the end of my JS 750 swap and need to figure out what prop to run.
The motor is a stock dual carb big pin 750 with a pjs 650 pipe, purple doo waterbox, rear exhaust, and a bunch of extra hull vents. I am running the Rhaas driveline conversion with a stock 750 pump and nozzle.
Currently the pump has one of the 5 blade cast impellers in it. I am considering adding one of the solas adjustable nozzles and stubby cones but am not dead set on it.
What would be a good prop to start with?
Sean
