I decided to tuck my primer away as to reduce the possibility of it being a shin buster. I had a nice open spot in the bracket area. It fits nicely. I also mounted the hood straps and the stainless steel eyelet for the limiting rope.View attachment 378382View attachment 378383
Attempted to dry fit the pump and shoe. Off less than an eighth of an inch to get the pump bolts in. Probably need another set of hands to help compress the pump seal.
I use an Irwin 24” pistol grip bar clamp to install pumps,,, super easy one handed install then once tight the clamp holds pump in place while you have both hands free to install bolts. Easily compresses seal as much as you need to line up bolts.
Works best if steer nozzle is off. Hook in pump inlet/shoe and other end on reduction nozzle and give it a few squeezes. Some intake grates may need to be removed but most big freestyle intakes are open enough to hook the clamp.
I’ll be there, looking forward to meeting you and the ski!I think I have an 18" Irwin, I doubt its long enough. Three able bodied adults should be able to get it in I suspect without the clamp but Im adding it to my shopping list for future builds.
Side note for anyone up in the great lakes region. Im planning on attending the Wave Rave free ride in August. Hopefully I will get a chance to meet some of you.
Thank you very much for the kind words. It truly is paying off. Hopefully I can get the Driveline in this weekend and get it out on the water , it depends on how everything goes together. It's not nearly as perfect as the pictures lead you to believe , I know where all the imperfections are lolThis is amazing. A work of art AND engineering. Crazy devotion. I love it.
