Problem solved Pics
casanova992
4U2NV
Margate, NJ
Good Evening gentlemen! Problem solved! I have spark now:biggrin: Special thankx and shout outs going to my man :hail: douglee25, thanx brother.. Apparently, the wire leading to the exiter coil was:frown: unattached, along with charging coil. Itz now resodered, and guess what SPARK BABY SPARK!!! The only other thing is determing whether or not the bendix is shot. It makes a weird noise, after a couple of cranks, like a rooster or something.. Doug, mentioned about a fine thin washer that goes on both ends of the bendix, I'm missing the one thatz on the cover side.. What do you guys think??
Gentlemen, itz always a pleasure...
Vince
The only washer on the cover side is the one that goes between the bendix and spring. It keeps the bendix seated so that must be there!
Also know that the brass insert pressed in the fly cover can get worn and elongated..causing noise or worse.
douglee25
m3booooy
South Jersey
Glad everything is good to go! I suppose the new washers and spring should do the trick. Thanks again for the tomato pie and the canolis. Madd good food! We'll def be riding this summer!
Doug
casanova992
4U2NV
Margate, NJ
I hear that, Doug don't forgetabout the summer kick off party at the shore.. I'll post a thread for the rest of you kats... Just a reminder though, I have a strick NO FATCHICKS ALLOWED POLICY...until after 3AM, then itz acceptable..
They don't call me Casanova for nothing...
Vince
Vince
no wonder you (and me both) have to get on-line based azz........we have a "no tops allowed" policy on my pool deck..
hmmn, I might just have to make a sign to make it official..
