300/440/550 Primer hook up?
I am going to hook up a primer today on a 550 and was wondering where I should tie the T fitting in? Also, what is everybody using to hold the brass fittings into the carb? JB weld or the such? Thanks
amemoryoncelost
X2/SNsj
tacoma, wa
Most people suggest using the return line, some people live by using the reserve. I'm sure you will get a few folks to suggest either and each person will have their own reasons.
So far as keeping the fittings on the carb. Yamabond, superglue or a simliar sealer should keep er in there.
good luck!
DAG
Charlotte, NC
I just T into my pickup line, their will ALSWAYS be fuel their. and their is no reason not to.
Whtbread
More Brap Please
south jersey
I just installed a primer set up from Riva. I put the T in the return line. After I got done I took a look at the directions and they stressed to use the reserve line but did not give a reason as to why.
