Power factory pipe setup/tuning
Octane_114
LeT tHe gOOd tImEs RoLL
Charleston S.C.
@MTRHEAD my man!
I didn’t believe those rpm’s were out of reach. I have tried an advent with the D23 curve set but all she would do is back fire. I didn’t have 2g’s for an msd and wanted to ride vs sit on the beach so I bought an oem ignition.
1. I don’t understand what you mean by the drag. It’s a -2 out of the mold by bullett v1 bottom.
2. I can share my curves from my advent D23 maybe you can explain why I doesn’t like it.
3. I believe it’s a C75
4. I can measure the new I have on the shelf so I don’t have to take my exhaust apart.
@MTRHEAD my man!
X2’s have a lot of wet surface
Sxi 22 and 21 curve is close to what I was saying timing should be at 7600-7800 rpm
ok. That’s a big pump. What nozzle?
stinger size and what about waterbox?
I'm about 95% sure that a Bullet V1 Gen 2 X2 uses a bottom deck that is a clone of an SXR, or at least really close.
This is based on spending way too much time staring at pictures of hull bottoms for a hull project I have been working on.
Octane_114
Charleston S.C.
it’s slightly modified, i scuffed the bottom, worked the intake track and from bullett it has tubbies/front sponsons out of the mold.
Octane_114
Charleston S.C.
it’s a short skat I believe it’s 89mm.
Octane_114
Charleston S.C.
Octane_114
Charleston S.C.
I haven’t touched this project all winter going to dust her off debating on installing the 49’s, check a few things and hit the water to she what she has.
I don’t know why she will not run the advent, all she will is back fire.
I know the a02t model works with kawi electronics just have to change the static angle to 47 degrees I believe from 56 on the Yamaha. I know the kawi is 9 degrees less than the Yamaha
