- NorCal
Im running dual 44 blackjacks on my 771 61x/62t that were built for my setup, I ran two tanks through them last time I was out and the ski was dailed in and running perfect. Carbs both set to 5/8 high, 1 1/8 low.. I was messing around doing some nose stabs and suddenly like a light switch it started bogging like I was out of fuel.. I was close to shore so made my way in and saw I still had a half tank.. Took the ski back out and now its loading up bad on the low end but once it gets to a point and clears out up top its fine, problem is off idle to to full throttle, just feels muddy/loaded up..
Checked compression, all good.. spark/ignition is good.. ski starts and idles just fine, just loads up now for whatever reason.. I pulled the A/F and look down the carbs and run it for a sec, then shut it off and one of the carbs dribbles fuel out of the orifices right above the butterfly when its off for a few seconds, kinda in a pulsing pattern, a good amount at that.. the other carb does not..
I talked to art a while back before this issue and he mentioned something about the diaphragms could cause and issue, it feels like suddenly I have a pop off issue but its strange that it would just come out of no where so suddenly like that..
Anyone have any thoughts what I should look at/for?
