possible dieseling in my roundnose. engine run-on
2006superjet
just one more part....
costa mesa ca
here is the scenario.
had about 1/4 gallon of fuel put 40/1 synthetic oil in enough for 3 gallons of fuel. note the 3 gallons of fuel not in yet. just lots of oil and a lil gas with yamalube in it.
i just installed new sparkplugs and started the ski. after giving it a few primer squirts. primer is hooked to the reserve and the reserve was selected on the fuel selector.
ski started a lil and i squirted a lil more in and then it went i gave it a lil throttle then let off and it shot up sounding like full throttle. pressed the stop nothing pulled laynard nothing then after about 9 seconds of running away it just stoped suddenly without me doing anything. the engine was not to hot just barely warm.
what could have happened.
oh and i put inspected the start stop looks good functions fine. got 3 gallons and filled it up.
then disconneted the primer and primmered it into a bottle to get the overly rich mix out.
she started and stoped using the button and lanyard. i reved it can it came down. all is good:lmao:
give me a reason not to worry about it scarry shiot
750SX
DO IT
Palmyra
IDK but if you put the oil in it, before the gas, your mix ratio could be off. I'm not saying that is the reason it Dieseled, I am saying that is a really stupid way to mix your gas.
SuperJETT
none
I'll say it again, when your engine runs away, hit/hold the stop button and PULL THE THROTTLE WIDE OPEN, it will eliminate the bypass situation and kill it.
2006superjet
costa mesa ca
does this
happen often? luckily I was not on the thing im just thinking it was caused by the oil thing and too much fuel in the carb area caused by the primer. i just dont want this to happen again.
Kennay
Squarenose for the _____
Myrtle Beach, SC
You could run straight gas and no oil and it wouldn't run away unless something else is causing it to do it. It wasn't the oil mixture. It wasn't from the primer either... too much fuel and not enough air won't cause the engine to run away. If was from a lean condition... air in the fuel lines, air leak at the carb/intake/reed gasket area...
2006superjet
costa mesa ca
ok
ill check all that stuff could have had some bubbles in the lines it was low on fuel. ill check all bolts and tighten things up.
why didnt it stop when the lanyard was pulled or red button was pressed.??
2006superjet
costa mesa ca
lol
ya i know its somthing to do with fuel or oil or sparkplugs the 3 things i have done since starting it..
i have to get this puppy 100% to be able to race this weekend.
750SX
DO IT
Palmyra
It can run with the lanyard off because a piece of metal gets that hot in the combustion chamber it ignites the air/fuel charge. It's called a hot spot.
wetjet701
Always On
Mine did that today also. The problem was the way I had me fuel lines ran.
I ran them fuel in main, return to the other carb main and that return back to the tank. I used T's and both in from tank and both returns to tank runs perfect now.
