Possible cavitation?
Was riding the other day and at the river I ride at there is some moss and sticks in the water. Never have a problem with them but the other day was heading back in and went over a little patch and it felt like my ski suck up some moss because it started to burn out like cavitation. So I stopped and check but nothing was there. Started back up and the vibration was still there.
Got home pulled the pump out everything looks fine. Pump is smooth, no noticeable leaks, having changed anything recently. Only thing I noticed that was different was that my pisser that comes off the head wasn't putting out as much water and the hand warmers that feed off the same line barely had anything coming out.
Could my midshaft housing have failed. Is there an easy way to check?
Big Kahuna
Administrator
Tuscaloosa, AL
if you have less water then you need to check for blockage. Did you pull the prop also? Also, depending on how much trash you ran over, you could have temperarily blocked the pump enough to create enough pressure that it may have sucked the Rubber Pump Seal in causing a leak there.
