Hello I'm trying to install this spring on the xft. I got the spring used has the prevous owner ground down the short side here? And does the short side go into the hole on the bracket and the long ride up the inside of the pole. Thanks
He is trying to install this in an XFT pole FYI
Mark44
i know. what i told him was for his xft pole and bracket.
Thanks Aqua Sergio pmed also. What I found is the location of the hole which is aiming down below the pivit bolt starts the spring off with zero tension. And begins to resist or hold weight when the pole is almost resting on the hood. On a Sj the short side of the spring aims up the pole above the bolt, begining tenions sooner when lowering the pole.
