Cannibal
Tasty Human
- Summit Lake, WA
Interesting project but those HTS-2000 brazing rods were made for small repair jobs and not a structural part that will see a lot of vibration and exhaust pressure. Those rods are made basically from aluminum and a zinc mixture. More zinc is added than with any conventional aluminum alloy to lower the melting point to less than that of aluminum so that the brazing rod will flow long before the aluminum gets hot enough to melt. If you want the part to last you'll need to use a 4043 filler alloy and TIG or MIG weld it IMO.
Hmmm, interesting. It sure contradicts what they advertise (of course they are trying to sell you something).
"When drawn over heated aluminum, HTS-2000 penetrates the aluminum oxide, creating a molecular bond that is stronger than the original commercial aluminum. Electrochemical corrosion is never a problem, because the electrode potential between HTS-2000 and aluminum is so slight. HTS-2000 joints last permanently in normal or protected environments. They will endure 10 years or longer under severe conditions. HTS-2000 joints are evaluated as permanent, corrosion resistant, and stronger than joints made by heli-arc machines and all other brazing rods tested."
It does say the material has to get to a certain temp to open the pores of the metal for penetration.
I'll probably give it a try just for the experience, or at least do some test pieces. If I'm not happy with the results, I'll have it tig'd up.
