Super Jet Piston wash picts
Proformance1
Liquid Insanity
New York Crew
Speaking of piston wash, from reading all I have on two strokes, and seeing these, I'm assuming that it was lean? The orange/redish hue is from the starbrite fuel additive, white chunks are saw dust from the bench top. Domes look the same no detonation, plugs looked great every time I changed them. Full throttle plug chop a nice cardboard color. Full throttle 5-10 sec runs, not a problem. The rings were shot, about 18 thou so I'm assuming that is why the sides of the pistons are so brown?
LEAN or Decent???
Proformance1
Liquid Insanity
New York Crew
Oil is Yamaha, 14 ozs per 5 gals so approx 45:1 ratio, 93 octane Sunoco with Star brite Star Tron Enzyme Fuel Treatment Gas Additive. There are small fingernail sized low spots in the carbon build up about 1/16" lower than the rest of the carbon build up.
Idaho
Looks a little lean to me. These were mine last spring. I was running real rich
ry%3D400
I dont think a plug chop after 10 or 15 seconds wide open is going to tell you if you are lean on top. The reason is it takes more than that to clean the plugs of the color you get from running the engine at the lower rpms you normally run at.
