Piston squish
Hey Guys
I did a little work to my stock 701 cyl. I had to take .020" off the bottom. I put her all together and checked the piston squish with some solder. I am reading .030" piston squish.
Should this engine be okay? I imagine it will make more power, but will it live?
Thanks
tricky1
XXX
Alabama
Hey Guys
Thanks
That's pretty tight. What's your base gasket thickness, and what head are you running?
Well, I am running a .020" base gasket, I think that is stock? I have the ada head and I have the 35cc domes in there now.
What are the issues of running .030" piston squish? Should I try to get .040"?
Thanks
