- edmonton
I know a stocker superjet 650 makes 50hp. But what is the ballpark horsepower with a full pipe? I've looked around and cant find any numbers. If it helps my ski has a full pro tec pipe. Thanks
That is pretty disappointing. Thankswhen i bought out coffmans, i got all their dyno test results for their pipes. bone stock 50.4 @ 6000. with their sizzler, a whopping 56.4 @ 6000. the #s go down as the rpm goes up or down. no pipe is going to get those #s any higher. tiny ports are the reason the 650 motors suck.
Stock 96 rn is 63hp
60hp @ 6250rpm to 80HP @ 6750rpm on the 61X motors with the coffmans rocket pipe. 20hp and 500 rpm gain.
A stock 61x cyl is good for 60HP with a stock pipe and in the low 70s with a typical wet pipe. In 1996 they added a carb and changed the HP claims to keep up with Kawasaki. Somehow the 95 blaster went just as fast as the 96 with 10 less HP. A coffman Sizzler made a noticeable improvement on a 650 cyl and is even better on a 701 cyl.1990-1993 50 hp
1994-1995 63 hp
A stock RN 1996-2013 is 73 hp
