Is there a target temperature for a PFP chamber when running wet? You have the temp strip on the chamber, but how accurate is it since the chamber is jacketed and the heat has to transfer through? I’m running a 70 jet right now and I don’t think I’ve ever seen my temp strip go past 122 degrees on the chamber. I think it usually reads 113 actually.
Also, last time I went out, I went to tighten the FCV and noticed I had it pretty much closed. My waterbox never goes over 131-140 range. I tried to test the pressure required to open it completely closed and it seems to be about 5-6 psi when it starts to leak. I tested a jetworks valve and it’ll hold a lot higher pressure so guess I should swap it out?
I was running wet because my 865 didn’t respond well to the dry pipe (power was very laggy) and I was much happier this way. I’m on an 1105 now and was debating going back to a dry set up.
