Petrol Problem
Hey Guys,
Ive just finished putting my tank back in the but now i cant seem to get any fuelin the primmer lines....
Anyone have any ideas?
I ahve already checked the primmer but that is working fine (it is pushing air through the lines)
Mike W
Infidel
North Florida
You have to make sure the 'T' is in a low point in the line. If not the primer can not pull any fuel out of the line because the line will be dry.
dbrutherford
Parts Whore
Fairmont, WV
Did you replace you fuel lines?
Did you prime them if you did?
To prime your fuel lines, take an air gun and put compressed air into the gas tank. That should help pressurize all your fuel lines.
I like ot pour a little gas down the carbs and get the engine running. After a few times of doing that, the engine will pull enough fule into the fuel lines.
SJ Thumpa
SJ THUMPA
Pressurise the tank. Disconnect the overflow line to tank (tank side) and blow into the line with the one way valve (white thingy) connected until a small trickle of fuel seeps out of the overflow line.
SJ Thumpa
SJ THUMPA
Ahh, its you Matt. Make sure you remember to put your cap back on.:banghead: If you havn't sorted it yet get my # off Scott and flick us a txt.
Yeah its Me :) I got it sorted this morning. My fuel filter was blocked. I was gonna head for a ride today but its to damn cold. I just put a -4" invert tech steering setup on my ski, I cant wait to try It
Leaving the gas cap off has to be one of the dummest things ive done :) I guess it was bound to happen at some point in time
