Ordering new engine gaskets...
The other Alex
(Jetdude)
Lake St. Clair--
Where is the best place to order gaskets from? I'm re-doing the top end on my 66E (Sort of, doing half of the top end...), and was going to order OEM gaskets from Riva, but then I got to the third one and the bill was already over $100. I looked on SBT and the same gasket is less than half the price...Are the gaskets from SBT the same material as the OEM ones? The OEM gaskets aren't that flimsy paper/cardboard material, but they are a lot more money if you are ordering more than two...
I need a Head gasket, Exhaust manifold gasket, carb to intake gasket(s), 2 cylinder to case gaskets, and powervalve gaskets. The powervalve gaskets I was just going to order from SBT in the powervalve rebuild kits (I'm also buying two SBT powervalves).
Also, where is the best place or person to order original mikuni rebuild kits for dual carbs? Thanks for any advice, haven't posted here in a wihle!
