No a 144 stuffer is not a direct fit into the 155. About an hour of fitting and grinding little by little with a dremel i was able to fit a 144 tbm into my oem 155 nicely. Its easily done.
It was a couple years ago but if i remember correctly it was the thickness of each vein needed to be widened slightly. Also the bore at the front needed to be a bit larger it think.
