Custom/Hybrid OEM pump shoe installation
When you're lining up your pump shoe for install you should not have the pump seal in there, you line it up and install without so when you do install the pump with the seal it makes a tight fit. When you are gluing it in it makes for easy clean up if you put masking tape around the shoe so you don't have a mess of glue everywhere to clean up. Just pull up the tape once the glue starts to set up and won't run any more.
baxt3r
BBQ
Charlotte, NC
I did it both ways. First time with the pump seal, second without. Made sure it was even all the way around without the seal. And I've already got the masking tape on. Just have to pull the trigger. Probably going to wait until tomorrow morning. Low temps overnight won't do the 5200 any good especially with no good way to heat the garage other than the propane heater I use while I am in here.
