Where is the best place to buy OEM fuel line? Seems like everyone swears by it now after the short rave on the colored fuel lines ended abruptly when the lines turned hard as a rock.
Check out Tygon Fuel line. I got mine in yellow. You can still see through but I hear this stuff lasts, although it is slightly more expensive. I think it's worth it though!
I've used some high pressure fuel injection fuel line from autozone that has worked very very well. Lasts for a long time and is steel braided re-enforced. It is just very very slightly larger on the outer diameter when compared to OEM fuel line.
wow... a little overkill? that line is meant for 40+ psi and it isn't 6+ dollars a foot because it last longer. the cheaper stuff is made from the same stuff just a lot cheaper because its meant for carbureted vehicles.
check out my build thread Weston's wdk rok the fuel and waterline is great cost is $2.00 per foot for fuel line and $2.50 for water line red or blue
I can get you 100% stainless or titanium clamps as well pm me for details
