Nynja pipe
I have a full 62t motor with 150 and 153 psi with dual 44s oem carbs and a full nynja TNT chamber pipe with flow control valve with a mag pump and hooker 9/15 prop. What would jet specs be also what should I set the tuning screws on the pipe for. I looked in the carb spec forum and couldn't find anything compared to my set up hope someone can help
I just opened them up the one had a 125 pilot and a 137.5 main not sure on needle and seat and spring and the other carb has a 125 pilot and a 150 main these carbs are way off I didn't jet then I just got the ski and tore it apart
