- Clearwater, Florida
I have a 1993 superjet with a stock 62t out of a raider with dual 38s. Ski has 150psi in each cylinder, good spark, always use 90 oct non eth, new jets 130 main 70 lower, new needle and seat with whatever the stock springs are im pretty sure. I'm pretty sure the adjuster screws are out about 1 1/4 turn to 1 1/2 turn. I tuned the carbs at the ramp and ran the ski between adjustments and checking the spark plugs each time. Ski was running great for a few months then recently started to bog and give me trouble starting after it was hot. It doesn't have the low end or mid range power it used to and it feels like it won't go WOT. After jumping wakes it really bogs then clears up after a little. My reeds are stock and in great shape too. I don't know what else to check. And I looked at the fuel pump in the carbs they are clean. Took the in line fuel filter out too and the pick up in the tank is clean.
