Nosestab feedback
Nose stabs are that one trick that everyone does a little different. Everyone has their own flare to it. My favorite is off a big wave in the surf and you end up doing a 360 stab. Dropping your shoulder as you hit the lip will help get you more inverted just make sure you have a good limiting rope. Over extending into the bars is no bueno.
i need to learn rolls im struggling
One thing that helped me was holding the handle pole low, like resting on the hood. When you're approaching the wake, take the final blip before WOT but make sure you "preload" and turn right, this offset momentum helps the roll "pop", AFTER your final blip before WOT takeoff, get the pole on the hood and try to keep tucked up and the pole closed. I was opening up like you do with a stab and couldn't keep momentum during the rotation, but you've got to stay tucked and keep the pole low! Your stabs look great, textbook even. Get to where you can do invert stabs or just turnaround stabs on command, riding out of both, then you're ready for sure.
thanks bro! ill try that next time i go ride (stator went out) need to get upside down
