nose stab help
cookerq62
Life's Been Good
Upper Bucks, PA
I was finally getting them solid off setup wakes. The key is make a 90deg turn to make your wake in the opposite direction you do the stab. So if you stab to the left like me:
1. turn right 90
2. go about 50 ft
3. 180 to the to the right and hit the wake
The best advice I can give for getting the nose down is to image your jumping over a fence and landing backwards. Thats how is feels when you get it right.
not sure if this will help or not , but here is a pic off me just leaving the water doing a nose stab on my x2. head right forward and steering on full lock shoulders and head pointing in the direction i wont to go, and nose off the ski nice and high so as you rotate round 180deg it will be nose down and rear off the ski high as it moves round the axis
im in the same boat as you man, ive only done like a dozen out of my attempts. If you have your rotation down then practice pushing down on your pole towards the pivot like a sub, and pull your legs up, thats what i did and its getting better and better.
