Super Jet No start
JHD
Colorado
Installed ADA head. Checked compression. Primer wouldn't get fuel to carbs and turned over multiple times trying to start. Dumped a little fuel in the carb. Started, ran for 5 sec, died and now I get nothing. Battery is good. Replaced s/s switch last spring and appears to be good. Where do I start?
JHD
Colorado
Not fuel. Once it started it sucked fuel through the lines. Primer now pumps fuel to carbs. Start button does nothing. Electrical problem. Nothing happens when I push the start button. Nothing.... Fuse in the E box is good. I did disconnect and tape off the heat sensor but it started after that.
I had this exact same thing happen to me earlier today, I disconnected the battery, reconnected it and it started up immediately, it's worth a try.
JHD
Colorado
Disconnected battery. Engine turned. Put s/s switch back together. Nothing. Disconnected battery again and again I get nothing.
if you dont hear the relay clicking. its most likely either a bad start switch or bad ground from batt. really just gotta chase it down with a test light or meter. not really gonna get an answer here. id start by opening ebox and checking for 12v at battery side of starter relay.... if u have 12v there then ur start switch prolly isnt sending 12v back to relay. try jumping the 2 prongs on the relay
Philip Clemmons
Owner, P&P Performance
Richmond, Va
Disconnect the clear start stop plug.
Verify you have 12 v on the red wire.
Jump red to brown on the E box side of plug.
If it turns over, issue is in start stop switch. If it still does nothing, issue is in e box.
