- Castro Valley, California
Well recently my 94 Blaster lost park. Pulled the boots off, unplugged the stop switch. Still nothing, what should i check next? Guessing the ebox but what do i test? Any help is greatly appreciated, thanks.
How do i test these?Test the wires coming from the stator to the Ebox to rule out the stator. Then test the coil. If all that tests out then throw a another CDI in there.
Found the problem, bad CDI. Will be ordering one from you.Test stator wires brown/white to ground and white/red to ground.
