- Shippensburg, PA
so, im currently deployed, but i had the wife pick up a blaster for me to ride when i get home. this blaster looks mostly stock with the exception of a riva red pipe, and a few other things.
the questions i have is, did blasters have ANY pissers from the factory? from what im seeing my new blaster has no pissers on the outside of the hull. does this mean that all the water is being dumped into the exhaust?
also the only cooling line i can see is from the rear of the cylinder to the head pipe.
im guessing that the cooling it coming in from the pump, to a T, to both sides of the exhasut mani, out of the rear cyl head, and into the headpipe. would the stinger's watter fitting be capped off in this scenario? i think i may see a water fitting on the cyl. head, front piston that looks to be capped off also.
does the factory cyl head have 2 cooling fittings? i seem to remember on my roundnose there being 2 fittings, but its set up for dual cooling.
any help would be appreciated, i dont think this thing is set up right cooling wise. let me know, i wanna fix, and ride this thing as soon as i get home!
