Hey everyone,
So I've been tuning my ski recently
(Heres the spec list to hopefully help you get an idea of my set up:
- 2014 Polar composites Trixstar freestyle jetski
- 61x 701 150/150 comp
- Msd enhancer
- Coffman sizzler
- TRD waterbox
- Carbon reeds
- 46mm true cad design red top annular discharge carb
- 130 pilot 151.3 main 2.0 n/s 95 gram spring
- ProK air Filter
- Rhaas engine mounts
- Hooker 9/15
- New kart tank
- X metal trim
- Flow control valve
- JRE Pump Cone)
(482m above sea level)
My initial problem can be found in the thread titled "falling flst on its face" but i now have a new problem.
So Ive managed to dial it in alot closer than i was with my original setup, however i still cannot get it to go from Zero throttle to wide open, originally this would cause it to lean bog now the ski completely dies.
But if i go from Zero throttle to 3/4 open the ski performs exactly as you would expect, and seems mint
So is this because the high jet is too rich? Or do i need to go down to an 80gram popoff? As reading the mikuni manual what i think its saying is its the high screw but I just want to make sure as ive been fiddling with this for way too long.
Also if anyone knows the difference between a carb and an annular discharge carb please let me know as i have had no luck finding a difference.
Many Thanks
- Msd enhancer
- Coffman sizzler
- TRD waterbox
- Carbon reeds
- ProK air Filter
- Hooker 9/15
- New kart tank
- X metal trim
- JRE Pump Cone)
Many Thanks
