New ADA Yamaha Cylinder
Don 79 TA
Still Fat....
adaracing.com
it's been on their site for a while
seems like they use sea-doo pistons to get the bigger bore
almost 1000cc's
not cheap though
especially considering the machine work involved and needing a crank
just wondering if they are going to have more torque then the current lamey setup i have
F
Freestyleriverrat
Guest
I would not dump the cash on it until I saw some reviews or some dyno charts on its performance
Don 79 TA
Still Fat....
thats why i'm asking to see if anyone has it, or has one on order
it seems to be a complete cylinder kit, i can only imagine it being slightly lighter then the Lamey, but is it as sturdy?
F
Freestyleriverrat
Guest
I have a Lamey and although its cast it is thick......I would not worry about breaking either one.
Mile9c1
X-H2O.com
Grand Rapids, MI
godocgo said:
cast is better for heat dissipation.
Actually billet has a higher thermal conductivity, so it is better at heat dissipation. But they are very close, it's not worth arguing about. If you have more billet mateiral by volume, it will hold more heat. And vice-versa.
Sleeves, by contrast, don't conduct heat very well. If you use aluminum sleeves instead of iron or steel sleeves, your engine will run much cooler (that can be good or bad).
Mado, relax, it just uses Seadoo style pistons!
