Need Some Help!!!
Ok all you pros out there I need some advice. I have the opportunity to buy either a
1998 kawasaki sxi pro or a 1990 650 superjet.Don't know which one I want??
1998 kawasaki sxi pro: (they want $1800)
-aftermarket R&D head
-aftermarket extended ride plate
-aftermarket bilge pump (currently not hooked up right, but its all
there for someone that knows which wires go where to do)
-original handpole was cracked so now has a used handpole from a 1995 sx750
1990 650 superjet: (they want $1500)
-MINT Condition
-comes with cover
-straight bars for freestyle
-primer
-single attwood bilge pump with switch
-aluminum finger throttle
-sometimes you have to unplug and replug the lanyard for it to start
Thanks for all and any help!!!!
Chris
romack991
homebrewed
Warsaw, IN
-MINT Condition
-comes with cover
-primer
go with a superjet, BUT...
bars, primer, bilge, throttle are not any mods that will increase the value of a ski. also unpluging and pluging the switch is a sign of it having corrosion, expect either to be cleaning it or shelling out 100 bucks on a new one. I wouldnt pay over a grand for a stock 650 like saki said.
