Need help with SXR!
I plan on modding out my 09 sxr through the winter ! I need some help ! I have a wet pipe and advent ignition on it so far and i am wanting more power out of the motor, I also want some suggestions on the pump end of the ski on what to do. I know the sxr hull is no good for flat water so i plan on building a good foundation with the motor and pump before I buy a new hull next summer ( if anyone has suggestions for hulls also feel free to let me know!!).
Thanks for any help!
djkorn1
kidkornfilms
Cleveland Ohio
One of the four Trinity hulls is the way to go. The lighter, the pricier... Order way ahead! He has lots to build...Any of his hulls will add a TON of power to your ski just from losing so much weight. They are also BULLETPROOF and he stands behind his work.
As far as power, leave your pump alone and get an aftermarket aluminum flywheel ($500) (best bang for the buck besides a pipe on a SXR). Then get your head milled from Group K or LPW ($100).....and order a flow control valve from Jetworks ($40) Dont worry about a prop or flame arresters...the ones you have are fine.
Proformance1
Liquid Insanity
Vendor Account
New York Crew
Best ride plate I've found for freestye is stocker D cut and if you want a pump cone go with R&D or TBM they are expensive but the best. Intake grate is really opinion some say stock I really like my skat intake grate. Trim I bought Skat, dont waste your time, useless with stock hull, wait till you get aftermarket hull.
SW UT
The Trinity hulls sound like the :):):):), but after reading about so and so having the worst service in the world over a 3 year span for ONE hull, I honestly couldn't consider that. I would go superfreak for a hull, or Rickter.
