SX/SXi/SXi Pro need help with 750sx
1) Is it turning over freely? (or is it slow, or not turning at all?)
2) Check for spark.... (If you don't have the little $5 tester light, then just pull a plug and ground it out and see if you have spark) Note Make sure you fuel is turned off I would also recomend using a grounding wire instead of just trying to hold the plug against a ground...
3) Compression
4) Fuel are you getting fuel when the fuel is turned on... You should smell it when you crank the engine over w/o the plugs in it...
3 Things make the engine run Fuel, Compression, and Spark. You are missing something somewhere.
when I have the plugs out, it turns over nicely and when i put the spark 0plugs back in it does for a sec and then stops. When i had the plugs out, i turned the gas on to see if fuel was getting in and i could definitely smell the fuel
