Blaster need help picking out a head
Blasterobb17
need water now.
nj
I have a 96 blaster with the dual carbs. I want to buy a head to get a little more power but I have no idea which one to get. Also can someone explain to me the difference between girdled and non girdled? The ski is stock besides a riva red pipe and tau ceti air filters. Thank u
964Chris
FREEdumb obtained
TEXAS
no need for adjustments......you use your stock head bolts along with the girdled bolts provided with the head.
Blasterobb17
need water now.
nj
Alright cool thanks guys. Just one more question.... do you see me having to rejet my carbs after putting the head on or do you think it would be fine?
ADA girdled head all the way. My only problem with a non removable dome head is that if you start modding the motor more, you gonna have to buy another head. Dont get me wrong coldfusion makes some sweet stuff. I have their mid shaft bearing housing.
I just dont like buying parts twice.
Blasterrobb where in jersey r you?
Blasterobb17
need water now.
nj
Ya I don't see myself modding out the engine anymore after the head. I'm in north jersey bergen county. But I ride at barnegat bay light house a lot and shoot up too greenwood lake some days
Here ya are ,what are you wanting to see ?
Oh yea -- I gotta laugh out of this statement ! Quote: ''Blasterobb17''
( Ya I don't see myself modding out the engine anymore after the head) !!!! ....... Thats funny ! The power bug is impossible to avoid!
munki63
Epoxy is my duct tape
Canada
Buy a head that takes ADA domes and only that type of head BECAUSE if you ever decide to send your motor to xmetal or jetworks for a big bore set-up they both use ADA domes for there set-up's and it will save you $$ down the road
This is my head
Blasterobb17
need water now.
nj
thanks alot guys i just wanted to see the head bolted in the engine. my blasters in the garage and forgot hot it looked for a little.
Im pretty much looking at the ada head kit from jetmaniac, i just want to know exactly what im getting myself into when im trying to install this thing (girdled bolts fitting, having to adjust the carbs)
i seriously appreciate all the info you guys are giving me
964Chris
FREEdumb obtained
TEXAS
it's a very easy install......the o rings can be a bit of a pain, but a little grease/vaseline will go a long way in helping to keep them in place. def. put anti seize on the girdle bolt threads before installing, they like to stick.
