I just bought my first stand up... a 94 SJ. The guy I bought it from got it from a friend that had a lot of work done to it but he didn't know anything about it. He said it had a different carb, head work, bored out, etc. I also found that it has a Riva red pipe, Moflo grate, Riva groovy ride plate, and a stainless impeller. The ski has a Solas sticker on it so I assume it is a Solas impeller. It was advertised as a 93 and didn't mention the pipe, grate, ride plate, etc. so I was very happy to see it was a 701 with those mods.
Once I got there, I found that it had about 150psi in the front cylinder but only 60 psi in the rear. I pulled the head off yesterday and was happy to see the head gasket was torn which would cause the low compression. However, I'm a bit confused on what work has been done. It appears to have 84mm pistons but a 6r7 head (650cc). He said it ran great when he put it away last fall. Here are a few questions:
Can I assume this is a 753 big bore engine?
Can I assume the head has been modified to work with this larger bore? If not, should I be looking for a 760 head?
Is a blaster 760 head gasket what I should get? SBT or OEM?
Can you tell if the cylinders have been ported?
What else should I be looking for in terms of mods?
What else should I check before bolting everything back together?
Thanks!
Thanks!
