- near Boston
Here is the story - Had problem with clicking and no start. Tested voltmeter at starter cable and decided to replace solenoid. Good news is now the engine is turning and has spark but it won't startup.
Before I had the problem with the solenoid the ski would startup first try but only run for a few seconds and then die. it would do this over and over. Managed to keep it going longer by adjusting carb screws a little. Put it in the water and with some use we had it going for about an hour or so (lots of fun) before solenoid died.
Now I have the new solenoid in and the thing turns fine but now won't start at all. I think it may be the carb screws I messed with but could it be something else?
I am not getting even a hint of the thing firing.
Thanks for you help.
