Need 08 SJ rideplate information
Is the 08+ SJ ride plate the same as the old Squarenose plates, with six bolt holes?
Are the holes in the same locations as the Squarenose plates?
Thanks.
Proformance1
Liquid Insanity
Vendor Account
New York Crew
I was told by Kevin at Wamiltons that it will bolt to a pre 08 hull just by drilling the two cast in areas out. SN or not, No cule
That's what I am after.
When I shortened my RN hull, I put the back two inserts into the same location as the middle inserts in a SN hull. This means I must use SN plates.
I guess I can also use 08+ Plates.
Watty
Random Performance
Australia
A stock 08+ plate is identical to the 96+ with the exception of the middle bolt holes. They are in the same location as the SN ones.
JetManiac
Stoked
Vendor Account
orlando
The stock superjet rideplates are the same size and same basic casting for all years of superjets.
SN stock rideplates have 6 smaller holes which can be drilled out and used on RN and '08-up sjs.
RN '96-'07 stock rideplates have 4 larger holes but the spots are there to drill for the middle holes. Can be used on '08-up by drilling the middle holes out. Can be used on a SN as is with 4 bolts or drill middle holes and use all 6.
RN '08-up stock rideplates have 4 larger holes but the spots are there to drill out the rear holes. Can be used on SN or pre-'08 RN after drilling out rear holes.
