I tracked down some missing pieces out of a VXR Pro I got a few years back when I did a motor swap on a customers SN Superjet , VXR's us quite a few Superjet parts, midshaft housings , pump housings, battery boxes and a lot of other stuff , the VXR shaft is longer but I have a SN driveshaft here to swap out.
I installed the Weeks Brothers alignment tool and did a preliminary shimming on the pump , it was way off needing a stack of shims on the back bolts , I need to do the dowel pin mod on my tool , mine was one of the first batch and didn't have the alignment dowels holes drilled into it making it not as accurate , also the pump shoe isn't back in the ski yet so it's all just mockup but I have it really close.
Anyway VXR's are like abox of chocolates , you never know what you are going to get , hiding under this one was a R&D toploader so I will be using that as well , the ProteC open grate can go on the VXR.
I had to come inside to escape the mosquitos , they were eating me for supper.
