MICRO SPECS;
-781BB with dual 38s, lightened factory flywheel, ADA head, and Jet Maniac fly wheel cover (BIG thanks to Chris and Blue @ JM)
-Jet Maniac Ebox refresh with MSD and kawi coils...red wires and braided nylon (Thanks Chris!)
-Factory B pipe ported by Wamiltons
-Re-turf by Eric Malone
-148 Solas mag pump with skat trak cut back prop
-Thrust trim
-X Metal cut and welded hand-pole (Thanks Eric!)
-Water line quick disconnects
-Push bulb primer
-Limited slip modded tank
-X Metal water-box
-Blowsion finger throttle and quick turn plate
-Modded straight bars (Thanks again Eric!)
-Triple water bypass
-Dual bilges with Hot Products bilge switch
-Alien Battery with Cold Fusion battery box
-Jet Works water control Valve
-Cold fusion fuel filter
