- Italy
I suppose it is like Blaster1 in betterCongrats! I’ve always wanted to ride and flip an Mx1
Loic tahiti !! You are a blaster legend for me , i have seen you video freeride 1000+ time, the best video ever, it motivated me to grow up and rideing! Honor for me. My next challenge is mastering the backflip with mx1 and after do a backflip with my blaster 1 1994 stock hull! .I suppose it is like Blaster1 in better
ahahaha thanksLoic tahiti !! You are a blaster legend for me , i have seen you video freeride 1000+ time, the best video ever, it motivated me to grow up and rideing! Honor for me. My next challenge is mastering the backflip with mx1 and after do a backflip with my blaster 1 1994 stock hull! .
61x case , 62t cylinder 84mm piston , 5mm strocker adr, monocarb 46 , 170 psi loki custom head, msd enancher , oem flywheel lightened, 148 solas mag pump , 9/15 impeller 148 , thrust trim .Congratulations and thanks for posting the videos too. What do you have for an engine and pump?
oem waterbox , oem tank , rickter mx1 weight 180kg , 396lbs61x case , 62t cylinder 84mm piston , 5mm strocker adr, monocarb 46 , 170 psi loki custom head, msd enancher , oem flywheel lightened, 148 solas mag pump , 9/15 impeller 148 , thrust trim .
but with the good wave you dont need power for do a backflip, in the video the engine didn't even come into torque and didn't reach maximum revs
Some other on « 2cvkiller » on you tube , its my buddie Mat youtube chain (the rider with me)
And the first one
