I have MSD on both my big motors no issues and technically if you read way into MSD it fires up to 20 times below 3000 rpm depending on how much time it has to continue to spark before it need to spark agian at proper time. But truth be told on hot spark is much better then many weak ones. So if you are running a single channel it 3000 is actually 1500 rpm before its mono spark per rev.
If there is anything I have learned about Jetskies and reliability its to by new parts and have them setup properly by someone if you dont know how. Listening to others and piecing things together makes for nightmares. No one can send you something and say its setup for your motor because your jetting, altitude and temperature will change things even if parts are all the same.
For example my ski in the winter the jetting is great but the summer its almost to rich. And if i play with the timing maybe take some out since it hotter it might change everything.
Battery going bad that quickly has to be some kind of short if its the MSD should unplug it and measure the load between its power and the battery with a multi meter measuring the amp draw.I have an RRP E Box so its a pain in the butt to make any changes! Do you have a picture of your set up? I let someone else try to dial it in and they did a poopty job so went threw the wires and soldered them together and I noticed the one stud for 2-3 small ground wires was loose. When you said you ran 3 ground wires what gauge wire did you run?
2 weeks ago it ran good but not the best the guy I let work on it smashed a wire in-between the lexzan glass and box and it sparked and the electronics went dead. Now it slowly cranks and kills the battery in less than 30-60 seconds. I even pulled a plug to make sure there was nothing mechanical wrong and check spark and the spark was hit or miss. I been messing with this thing for so long I just want to ride! I don't know if there is a special set up that I can run but I have it 30deg advanced I believe and switches are right I believe. I wonder if a coil is bad or the MSD box is bad? Im lost.
Any help would be much appreciated!
Thanks Mickey
MSDIm still having problems Im ready to buy a new set up? Need help!
I have a spare MSD system I might part with. Im developing my own system now but its not ready yet. it will be much more then any ignition on the market right now
I may be able to help you fix yours if you have MSD
I was telling him to go MSD. The TS2 will kick randomly, can be used on a small engine as it won't break bendix/starter.I may be able to help you fix yours if you have MSD
So after reading through this entire thread and many others on the MSD Total Loss and the ATP Flame TS2, I am still having trouble deciding on which system I should go with. I really like the fact that the ATP Flame TS2 fits inside the stock electrical box. I ride almost 100% in fairly salty brackish water, so either way I go the system will need to be enclosed. On that basis alone, I want to go with the ATP Flame TS2. My biggest concern is the comments about them not being well suited to Large CC Stroker Motors and that the MSD is going to offer more power. Any advice?
There’s a 3rd option of adjustable ignition that fits in an enclosure.. uses 760 starter and cover/flywheel and rear Ebox plate .. you seen those ? Zeeltronics....
yes but thats not an issue at allYea I have heard of those, but I have only briefly looked into them. They still only use single coils though right?
No difference to how your engine will run. If they tell you different they either dont know or do know and are lying
