Msd total loss help
wikstromm
Washed up hillbilly
SE
Hey! Any msd total loss ninjas that could help me with translate this settings?
In my opinion they seem kind of way to safe/low?
Sw 3
1 on, 2 on 3off 4off
5on 6on 7off 8on
Sw 2
1off 2off 3off 4off
5off 6on 7off 8off
Sw 1
1off 2on 3on 4on
5off 6on 7off 8on
wikstromm
Washed up hillbilly
SE
Ah thanks!
Running a xs1000, rrp, dasa 48s, 155 skat sb
Flatwater
This is what i got from rick at xs so o guess i re set it at this when its ready
SWITCH 3
S1 S2 S3 S4 S5 S6 S7 S8
ON ______x_______ *_____________x____x
OFF _x________x___*_____x___x__________
5000 RPM 9250 RPM
SWITCH 2
ON ____________________x____x___x____x
OFF _x___x____x____x___________________
SWITCH 1
ON ______x____x____x_______x____x____x
OFF _x_________________x_______________
wikstromm
Washed up hillbilly
SE
What do I do wrong?
Im trying to set static timing to 31* but I bottom out the adjusting holes in the stator already at 20*
wikstromm
Washed up hillbilly
SE
Locating the tdc with an indicator in the sparkplug hole and a degreewheel on the flywheel bolt.
Tl set to Led function
Jcary85
Glenmoore pa
Ok, then what? you need to then create a pointer of some type, then rotate the crank clockwise slowly until the light turns on. Whatever degree its at is your static timing.
wikstromm
Washed up hillbilly
SE
Ofc i got a pointer, just got it, thanks for the help, i didnt get the right clearence for the pickups correct, the degrees were not consitent when I did mor testning
