speedysprocket
Alex
- Chesapeake, VA
I think my 42351 total loss brain is no good any more, but I'm just wondering if any one can confirm from prior experience before I buy a new or used one (anyone have one for sale).
Tried to ride and ski kept dying. Discovered after that some heat shrink on the common wire the coils share, which is positive, came off and the wire grounded out.
I got the ski running again, and water tested today. Ski will idle fine up to 1/4 throttle. If I go much above that, it'll feel normal for about a second, then it's like a 1500 rpm rev limiter kicks on for 3-5 seconds. Like as soon as the timing retard starts, it screws up. Anyone else ever had such a thing happen...?
Thanks
Thanks
. Cool wiring and grounds is s given. As Daryl said, you have a spare channel too. I'd switch each channel to the spare as a last resort to rule out a bad channel.
