Freestyle msd timing question 10mm on pump gas?
michigan
well im getting lot of different opinions on where i should set my timing so figured id get a few more.
motor is a dasa 10mm 1000, dual 46's, bpipe, solas 144mag, with 14/19, msd dual digital total loss, 195psi compression, runnin premium pump gas. been running it at 27 degrees timing and wondering what everyone else is running. what do you think im safe going up to on pump gas?
I run less compression 165 ish and am pulling 32 degrees on 91 octane with no problems but its the total package which allows someone to do this.
