There was a lengthy thread concerning keeping the electrical box dry. If you do use grease on the gasket be very careful because it will tend to squish out more easily. Personally I have never used dielectric grease on anything other than actual electrical connectors to help waterproof and combat corrosion. If your box has been wet inside before then you will have trouble sooner or later anyway. If not then be very careful to not pinch any wires when reassembling. I have had my enhancer for 8 years and it has never given any problem. Never spin the engine with the plugs out unless you have the wires grounded with old plugs or grounding lugs. If not the energy from the coil will feedback and can damage the CDI.
