MSD enh. wiring problems.
Foximus
CFL Cheapass.
Oviedo, Fl
So I put in the enhancer last week and it ran great. But for some reason the stop circuit didnt work anymore.
There are 2 white wires coming from enhancer CDI and 3 (if I remember...)
It says in the MSD instructions, that if you have 61x electronics you need a jumper to turn a male connector into a female... Well I have 62t stator, and I'm pretty sure I got everything wired up but still no stop switch.
Could I have gotten the white wire from the stop switch mixed with the connector that goes to the white/red wire to the stator, and still have the ski run great?
Ideas?
Foximus
CFL Cheapass.
Oviedo, Fl
I went over my wiring with a fine tooth comb.... and according to the MSD wiring diagram it is correct. Though I will say that diagram is complete crap... you can barely read it, all the wires cross over and intersect each other.
Ah well. Guess I'm just gonna have to go over everything with a voltometer.
