Want to Buy MSD ECWI module 42592
Looking for an MSD ecwi module #42592. Mine as you can see can no longer be fixed. The white feed wire has broken for the last time and I'm down to the circuit board level.
The module just cant get a signal.
please pm if you have one. price or trade
did you try using the grey wire connected to primary of coil?should trigger it.
and if just a nub is left on the white wire you should be able to solder something on there again.
I can’t get the solder to work with the portion left. The solder is now down to the Circuit board. I could run the wire into the stock electrical box to go off the coil feed but didn’t really want to do that.
What really upsets me is at one time I had 4 of these exact models and sold them
