I have read other threads on here about setting MSD up but I cant find dip switch instructions for the total loss i have. The dip switch diagram i found is shown in the picture attached. Anyone have a document explaining all the dip switches.
The MSD site has static timing an installation instructions but not a dip switch explanation.
https://www.holley.com/products/marine_and_powersports/watercraft/parts/42380
PDF here
https://documents.holley.com/42380.pdf
I can find instruction on a different model total loss in attached pdf which mostly explains it if this works the same as my model. I have attached PDF but the part number and dip switches are different.
This 4244 part number pdf has some differences and I am confused with a few settings.
- why my msd have deg+15 with two numbers for max speed retard.
- If i set max timing to MAX the pdf says for the other part that this is setings retard to -5.
- its missing these so i dont know what they do
- - max/min rev limit +4000 RPM
- - max retard retard +15
- - elec start
start ret
retard begin rpm
PDF here
- - elec start
start ret
retard begin rpm
